Same as Blu-ray, DVDFab 9 does not support to convert any DVD movies into 3D FLV format any longer due to the limitation of FLV itself. So, please select other video formats which can hold HD contents, like MP4, or MKV, etc. DVDFab 2D to 3D Converter is a born 2D to 3D converter software  which works with DVD Ripper convert 2D DVDs into a range of 3D videos with very impressive 3D effects.
This tip below serves as a guide for you to do that:
2D DVD to 3D Video Converting > Step 1: Download and install the latest DVDFab 9 onto your computer;
2D DVD to 3D Video Converting  > Step 2: Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the regular DVD you are about to convert;
2D DVD to 3D Video Converting > Step 3: Click the Profile Box (or Profile Icon) which takes you to DVDFab Built-in Profile Library, and then select one profile from the “3D Format” column, according to what video format your 3D device is able to play back;
2D DVD to 3D Video Converting > Step 4: Click “Advanced Settings” button behind the Profile Box to do corresponding settings regarding to video, audio, subtitle and 3D formats;
2D DVD to 3D Video Converting > Step 5: Click the “Edit” button at the top right corner of Operation Window if you want to customize the resulting 3D video. After you have done here, return to the main interface to “Start” the converting process.
Product you need order: DVD Ripper and 2D to 3D Converter
For more info, please go to: www.dvdfab.cn/2d-to-3d-converter.htm
